Would a bad temperature sensor throw a code and/or show up on a VAG?
I'm guessing it's a sensor and the engine is not actually running cold all the time.
or could this be a bad thermostat?
If it's still pretty cold where you are I would imagine it would be hard to tell. During the summer, mine would heat up on 100* days, but very slowly. Then once it started to get cold it never got up to full temp.
So pretty much what I'm trying to say is, if the gauge does move around based upon speed, it's probably the T-stat. If the gauge is constantly in the same spot, it's something else. But like I said you may have to wait for warmer weather to see a difference depending on where you live.
One just died Nov. 2nd coming home from Quattrofest 2008 in Portland. This one was located up uder the dash and behind the radio.
It is a Bosch controller motor
Part # 0 132 801 029 944
