Cam Chain Tensioner Seals Replacement Issues APB Engine Code
So I rushed on this job (like a dumb ***) and right after I over tightened the 3366 (aftermarket from ebay) tool I stripped the CCT plate it connects to.
Aside from removing a cam shaft, is there any other way to gain enough clearance without the spring compression tool to change these seals? If I must put the lock carrier into service position and throw the cam bar & crank plug on I will but.... It's a PITA so I'd like to avoid it.
HELP!
I didn't not put that pin on due to all those obstructions. I now suspect that it is the root of my trouble now (see the "P0346 code, ..." thread).
If you skipped this part your timing isn't 100% correct. The only 100% correct way to set the timing is:
1. Set the the crank pin
2. Set the cam bar tool
3. Unscrew the bolts about 2mm or 3mm from the center of the cam sprockets
4. Use a gear puller to pull the sprockets off a LITTLE bit until they can spin free (somewhat) from the wings that are keyed onto the camshaft.
5.Put the belt on the correct way, pull belt over tensioner pulley, make sure its snug and laying correctly then pull the pin on the dampener.
6. Put torx bit into tensioner roller & torque the belt to 15NM
7. Then torque the cam sprockets down to 55NM
8. Remove Cam bar, crank pin, reassemble and your timing is as perfect as is humanly possible.
(optional) after about 3K miles, take it apart again, and repeat belt procedure (with the belt you put on 3K miles ago) These belts aren't made to "stretch" but after it wears in and stretches 1/2 - 1 tooth worth of cam sprocket movement it wont be perfect. I do this to every timing belt I change because it noticeably makes everything that much more smooth.
Luckily for me, its been 2,700 since I changed my timing belt, so I feel a little less stupid that I have to get all in the timing cover again to lock TDC in place to lift this intake cam up. & my T30 bit just fell behind my engine mount & is being a little running ***** and not coming back! YES!!!... not
a. have a P0346 code or other cam position bank code
b. car runs like crap
c. misfires
d. Valves collide with pistons and your engine is destroyed
was your crank perfectly at TDC when you finished tensioning the belt to 15nm?
https://www.audiworld.com/forums/sho....php?t=2833885
I have read several guys saying the engine can run fine with that marker off a little. 2mm on the damper equals even less on the crankshaft, much less than one teeth.
When I recheck the belt, I will try to tension it with the back plate (TDC arrow) and the damper on.
Downside is I had to remove the lock carrier to set timing to TDC to move the cam. So the 1 hour total it takes to put the lock carrier into svc position & reassemble + 30 minutes to lock timing VS the 2 hours I feel I saved leaves me at a ?
Followed same procedure on drivers side without using VAG 3366 finished an hour sooner than usual & I feel the area was much more thoroughly cleaned than would otherwise be possible.
Waited 24 hours, fired her up, runs great, drove it hard for an hour, checked for oil leaks, detected none....
No cam position codes, misfires or any immediate sign of cam wear, timing chain noise or anything else I don't want to see/hear.
