OBD2 code P0420
Old Jan 28, 2020 | 07:02 AM
chrisaudiman's Avatar
Default OBD2 code P0420
Am having this code P0420 come up every few days and resetting it with a cheap OBD2 reader. It says cat is no good on bank 1. I have run cat cleaner through it but no joy.
I understand this code causes some headaches for other Audi owners. I have a 2005/6 A6 V8 running well other than this. Could it be the Lambda sensor is it worth changing this?
Just looking for some advice before changing the cat which is very expensive. Just annoying having the emission light coming on every few days.
Old Jan 31, 2020 | 07:39 AM
Chachboi's Avatar
if you have access to a bore scope, remove the rear O2 sensor and insert the bore scope, looking inside the cat. If you see a melted blob of cat material then you need a new cat. Labor is very expensive as this takes a large amount of labor hours.
if you need to pass emissions or just want the light off, I am not recommending it, but have heard of it being done, people will sometimes take a 2 pack of spark plug extenders from the local autoparts store, and drill them to a larger hole size to space the O2 sensor and get rid of the check engine light. Keep in mind though that this is illegal as it is tampering with the emissions system.
Quattro Jones
30v V6 Discussion
Nov 8, 2011 09:11 PM
audiquattroduo
9
Jun 21, 2008 04:53 AM
CapeCodAudi
Nov 1, 2007 06:11 AM
geauxfaster
Aug 19, 2005 11:55 AM
geauxfaster
Aug 17, 2005 06:51 AM
