00' non xenon headlamps same as xenon headlamps?
Old Aug 28, 2002 | 09:11 PM
KraZy007's Avatar
New Member
Default 00' non xenon headlamps same as xenon headlamps?
Is there a difference in the projectors of a non-xenon headlamp and a xenon headlamp?
Basically, will adding xenons to a non-xenon headlamp be equivalent to factory xenons? Are euro spec headlamps better in some way? thanks
Old Aug 28, 2002 | 09:17 PM
PDX-Boy[hermit mode]'s Avatar
Senior Member
Default If you liked melted plastic....
Stick Xenon's in stock '00 Halogen casings. However, if you are the wise man that I know you are, You'll buy Euro spec S4 casings that have the proper fit for Xenon lights in your A4.
Old Aug 28, 2002 | 10:29 PM
jasyn³'s Avatar
Senior Member
eh? youre not going to melt anything. xenons run cooler than the stock halogens
Old Aug 28, 2002 | 11:03 PM
Senior Member
Default I've seen some hairy stuff before, including melted housing...
If not properly inserted correctly... well, you get the idea.
Old Aug 29, 2002 | 02:18 AM
KraZy007's Avatar
New Member
do stock and eurospec use the same type of xenon bulbs? thanks
Old Aug 29, 2002 | 04:11 AM
WJM's Avatar
WJM
Tech Guru
Default Audiboy256, you are FOS. Krazy007 read on (more)
Krazy007 look in the tech section.
No the housings are not the same, but
yes the non xenon's can be used for a xenon conversion
the bulb types are different H7 vs D2S
hope that helps
Old Aug 29, 2002 | 07:47 AM
Senior Member
Default Okay chief, but you have to remember... if the conversion isn't done by...
someone who knows what they doing.... If I had pictures I would post them, by whatever bud, you can say i'm FOS.
Old Aug 30, 2002 | 08:39 PM
SmokinS4™'s Avatar
Default Just get a set of the OEM ones - I got a set for sale =)
<ul><li><a href="https://forums.audiworld.com/s4/msgs/941525.phtml">https://forums.audiworld.com/s4/msgs/941525.phtml</a</li></ul>
Old Aug 30, 2002 | 09:24 PM
jasyn³'s Avatar
Senior Member
well .. xenons are xenons. quality among diff manufacturers will vary of course
adminisTerTurbo
A4 (B7 Platform) Discussion
Nov 29, 2007 03:16 PM
Sparta_S4
Mar 22, 2006 03:25 PM
jerobean
Jul 17, 2003 09:04 PM
dr.audios[the OG]
Nov 24, 2002 07:58 PM
YHL
Feb 18, 2001 06:23 PM
