034 Snub Mount w/ Bracket Question
Old Feb 6, 2008 | 08:04 AM
Nor's Avatar
Nor
Junior Member
Default 034 Snub Mount w/ Bracket Question
Folks,
I just purchased the 034 snubber with bracket and am curious about how the bracket is used? How is the bracket installed? I did not get any installation instructions with the kit. TIA
Old Feb 6, 2008 | 08:22 AM
slightly disgruntled's Avatar
Default Take the old one off and install the new one in it's place.
Assuming that you can get the old one off, you'll see that it is quite obvious.
Old Feb 6, 2008 | 08:39 AM
Monkeyboy's Avatar
Default look around...
The 034 snub is a tight fit into the 034 bracket. You can try to heat the snub in the microwave, lube it, etc to ease the installation. (I would not trim it as suggested in the article). If you can't get it fully seated, it should suck itself in once you tighten everything back up (bumper).
Allow car to idle before fully securing the bracket bolts.<ul><li><a href="http://forums.vwvortex.com/zerothread?id=3231307">034 snub install procedure</a></li></ul>
Old Feb 6, 2008 | 09:02 AM
Nor's Avatar
Nor
Junior Member
Thanks guys. I got it figured out now
Old Feb 6, 2008 | 12:01 PM
ARCJr.'s Avatar
Default Re: 034 Snub Mount w/ Bracket Question
FYI, for my 01 A4, the OE bolts were too long to use with the 034 bracket.
Old Feb 6, 2008 | 01:10 PM
Monkeyboy's Avatar
Default same here
had to dremel @1/4" or so off of the OEM bolts.
jwood_a4
Dec 31, 2006 01:19 PM
Ballistik8
Oct 19, 2005 03:27 PM
S4orce2001
Oct 18, 2004 12:28 PM
bradvan
Jan 14, 2003 06:15 AM
SlammedA4
May 20, 2002 01:47 PM
