Is the 1.8T an interference engine?
Old Jan 15, 2002 | 01:13 PM
JakeL1.8T's Avatar
Default Is the 1.8T an interference engine?
i.e. if my timing belt snaps, do I have 20 valves to replace?
Yes, I'm a DSM owner, could you tell? :-)
Old Jan 15, 2002 | 01:19 PM
markbradford's Avatar
Rest In Peace
Yes, unfortunately.
Old Jan 15, 2002 | 01:24 PM
RKA's Avatar
RKA
AudiWorld Uber User
You will have UP TO 20 valves to replace (depends on your luck).
Old Jan 15, 2002 | 01:26 PM
BoulderA4's Avatar
Default Regarding timing belt - I have warranty until 75K, should I replace at 60K or wait
and see if it breaks before 75K and get it replaced under warranty?
Old Jan 15, 2002 | 01:28 PM
RKA's Avatar
RKA
AudiWorld Uber User
Default Timing belt is age and mileage dependent. If you're going to gamble, make CERTAIN that any possible
repair will be covered under the warranty. Talk to a person, and ask them...get their name. You're not talking small potatoes here, if the belt does break prematurely.
Old Jan 15, 2002 | 01:35 PM
BoulderA4's Avatar
Default Here are the exclusions - is the timing belt considered a drive belt?
Carburetor; battery; shock absorbers; manual transmission clutch assembly; friction clutch disc and pressure plate; throw out bearing; manual and hydraulic linkages; distributor cap and rotor; safety restraint systems (including air bags); glass; lenses; sealed beams; light bulbs; brake rotors and drums; exhaust and emission systems; weather strips; trim; moldings; bright metal; chrome; upholstery and carpet; paint; outside ornamentation; bumpers; body sheet metal and panels; tires; wheels/rims; GPS navigation systems; phone systems and TV/Video/Entertainment systems.
Maintenance services and parts described in your vehicle's owner's manual as supplied by the manufacturer and other normal maintenance services and parts including, but not limited to: Alignments, Wheel Balancing, Tuneups, Spark plug wires, Glow plugs, Hoses, Drive belts, Brake pads, Linings and shoes, and wiper blades.
Old Jan 15, 2002 | 01:40 PM
rigor's Avatar
Junior Member
Default Timing belt failure == its on you.
Well sorta. If the timing belt is specified to be replaced at 60K miles and you dont do it, then its on you. But technically a timing belt is a drive belt..
Old Jan 15, 2002 | 01:42 PM
BoulderA4's Avatar
thanks for the info - I guess I better plan on doing it at 60K
 Pouria Savadkouei
 Michael S. Palmer
Old Jan 15, 2002 | 01:45 PM
RKA's Avatar
RKA
AudiWorld Uber User
Default It's not spec'd at 60K, it's spec'd at 105K (or something like that), but I definitely agree!
If that belts snaps, it qualifies as an exclusion.
Old Jan 15, 2002 | 01:47 PM
JakeL1.8T's Avatar
Default So that said, why are so many engines designed as interference engines?
What is the reason that's done? I know on older V8's they have valve reliefs in the pistons, why has that fallen out of favor?
the Toyota hi-po engines are *not* (MR-2T, Supra TT), I understand most Honda motors are, the 1.8T is, the DSM's 4g63 is. What's the deal, anybody know?
-J
