150?
Old Aug 20, 2007 | 04:38 PM
Group 44's Avatar
Default 150?
My oil temp always reads 150 or a speck over.I have a 2000 A4 Quattro wagon. IS this normal?
TwentyValveB5+S4's Avatar
AudiWorld Expert
I would think it should be higher, 180-220 range.
Old Aug 20, 2007 | 05:10 PM
kenny (dremel)'s Avatar
Default if your trips are 2-3 miles, yeah, that's normal.
Normal operating temp hovers between 200 and 225.
Old Aug 20, 2007 | 05:19 PM
TristanP's Avatar
Default Like kenny said
Normal if the drives are very short. If they're not so short, there's a problem. If the drives are short, make sure it gets out on the highway (or even better - backroad romp) occasionally to burn off the crap that will accumulate in the oil. Normal operating temp is 200ish.
Old Aug 20, 2007 | 06:18 PM
n0yxl's Avatar
My needle usually lays smack dab center of 150 and 250, when up to temp.
Old Aug 20, 2007 | 06:22 PM
TristanP's Avatar
That would be 200
Old Aug 20, 2007 | 06:33 PM
n0yxl's Avatar
Yes, you would be correct
Old Aug 20, 2007 | 06:34 PM
shawfm's Avatar
Default If that is the true temp, sludge is in your future.
The oil should get upto between 200 - 225 to let moisture on other volitiles burn off. 150 is a bit hotter than Death Valley, CA but not by much.<ul><li><a href="http://www.weather.com/outlook/travel/businesstraveler/tenday/USCA0286?from=36hr_topnav_business">Death Valley 10 day weather </a></li></ul>
Old Aug 20, 2007 | 08:31 PM
slightly disgruntled's Avatar
How is your coolant temp? I used to have that when I has a stuck open thermostat....
Old Aug 21, 2007 | 04:54 AM
Group 44's Avatar
Default Re: How is your coolant temp? I used to have that when I has a stuck open thermostat....
Right in the middle never any higher,,,,
thx!
