3 beep... Error!
Old Sep 26, 2009 | 06:38 AM
Ohboy77's Avatar
Default 3 beep... Error!
I have an signal after 5 second the car run.
It's a red thermometer flashing and it's making, I'll said' 3 long beep.
I can't find my book. Can someone help me?
Old Sep 26, 2009 | 06:45 AM
4Driver4's Avatar
Tech Guru
Tech Guru
Did you check the coolant level?
Old Sep 26, 2009 | 07:04 AM
Ohboy77's Avatar
Yes I did and It's at Max.
Old Sep 26, 2009 | 07:10 AM
Ohboy77's Avatar
Could it be transmission oil?
Old Sep 26, 2009 | 07:24 AM
4Driver4's Avatar
Tech Guru
Tech Guru
Nope. Coolant. Either bad coolant level sensor (in the tank) or bad coolant temp sensor.
Old Sep 26, 2009 | 04:41 PM
600whpA4's Avatar
Could be one of the wires to the coolant tank plug broke or the plug fell off.
You can jump the 2 wires to see if it is in fact a bad wire or bad sensor in the coolant tank.
Old Sep 27, 2009 | 06:14 AM
Ohboy77's Avatar
The problem was the plug under the coolant tank. It was not properly insert. Thanks!
Rune Korneliussen
Apr 16, 2013 01:04 PM
dubblrest1985
Audi 100 / A6 (C4 Platform)
Dec 18, 2010 12:28 PM
Fidelity101
May 31, 2010 08:31 AM
slotsmd
Jan 27, 2009 08:52 AM
white90+hibredS4
Apr 22, 2004 03:52 PM
