6 disk cd changer cd err3 fix
discovered the cause was the changer mis aligning the disks when inserting them back into the cd holder, it would attempt to put 2 disks in the same slot which would make it jam and produce the code
simple fix
the jam kept happening on cd1, so i stopped putting a cd in cd1, now disk 2 gets randomly placed in cd1 or cd2 when i change cd's, so put fewer cd's in the holder, start with leaving cd1 empty
and if you cant remove the holder from the cd changer you will have to use a very small screw driver to roll the top/rest of the cd into the holder so it can be removed, may be tricky since your jamming 2 cd's together, but you dont need to take the whole thing apart
hitting the changer real hard from the side the door slides over to, to remove the holder works aswell
