Old Feb 13, 2002 | 08:45 AM
nospek3's Avatar
Senior Member
Old Feb 13, 2002 | 08:47 AM
Kris Hansen's Avatar
Head Cat Herder
25 Year Member
None. They are identical.
Old Feb 13, 2002 | 08:48 AM
nospek3's Avatar
Senior Member
Old Feb 13, 2002 | 08:50 AM
djnelsen's Avatar
Elder Member
Hp is measured at its peak. Not directly related to acceleration.
Old Feb 13, 2002 | 08:51 AM
Sourdough Josh's Avatar
Default The change in 0-60 time is due to 2 things:
1. The tip is 150 lbs heavier than the manual.
2a. A tip is forced to go through the entire RPM range in 1st gear before hitting the power band at 2500 or so where the turbo kicks in.
2b. In an auto, there is a torque converter, which has additional losses before it gets into fluid lock. However, this occurs only near idle speed, so it has no effect on most of your driving (again, just at a start)
Old Feb 13, 2002 | 08:53 AM
The power curves at the wheels are identical, too. Not just the peak.
Old Feb 13, 2002 | 08:54 AM
nospek3's Avatar
Senior Member
Perpetual Novice's Avatar
Doesn't a torque converter have more frictional loss than a clutch?
 Michael S. Palmer
Old Feb 13, 2002 | 08:57 AM
ColoradoMark's Avatar
25 Year Member
plus shift speeds will +/- depending on driver
Old Feb 13, 2002 | 08:58 AM
Not once it reaches fluid lock.
