if you do do it though, like i said penetrating grease. remember to put a new gasket in there. get at least 1 extra bolt / nut, because you're going to break at least one (you can return if not), take off your pass front wheel, you can reach the bottom bolt through the wheelwell.
good luck. plan on blowing a whole day doing it. then if it takes less, you scored.
