A4 Ash Tray stuck closed Any Ideas?
Old Jul 26, 2002 | 12:58 PM
2tuŽbos1mission's Avatar
Default A4 Ash Tray stuck closed Any Ideas?
I have in my fleet of audi's a 1999 Audi A4 2.8Q. The ash tray is stuck shut and I cant get it open any ideas Banging on it for 10 minutes didnt work neither did prying it open with a screw driver.
Old Jul 26, 2002 | 01:01 PM
Kirath ž-B0§t0n's Avatar
Elder Member
Mine too - its cause I put change in it and now its stuck behind it
Old Jul 26, 2002 | 01:03 PM
That's what i did. How are you going to get it open?
Old Jul 26, 2002 | 01:07 PM
Deerslayer's Avatar
Member
Default This is guaranteed to work...
1. Drill a 3/8" hole in the front of the ashtray.
2. Insert a molly bolt into the hole, attached to a length of chain or nylon rope.
3. Run the chain or rope through the sunroof and tie it around a tree behind the car.
4. Accelerate briskly.
Ok, here's another idea: pop off the plastic cover on the front of the ashtray. There's an indentation under the lip that you can get your finger or a bent coathanger in, and you should be able to pull it out.
Old Jul 26, 2002 | 01:13 PM
samjogo's Avatar
Member
i can't tell if you're serious or not... hahah
Old Jul 26, 2002 | 01:18 PM
SameerP's Avatar
Default will any kind of tree work, or is a certain type of tree best?
Old Jul 26, 2002 | 01:21 PM
Deerslayer's Avatar
Member
Default I like pine trees for this kind of thing, because they have a deep root...
but if you live in the desert or something, talk a big guy into letting you tie it around his waist.
Old Jul 26, 2002 | 01:31 PM
Default a nice big oak tree did the trick for me
<center><img src="http://www.artificialhorizon.com/imagehosting/diaz-anime.gif"></center><p>
Old Jul 26, 2002 | 03:27 PM
Bert's Avatar
You need some ash tray fluid ;-) You'll find it next to the boost fluid.
Old Jul 26, 2002 | 03:55 PM
SpyderSE2(movie man)'s Avatar
Looks like your going to have to take it out to get behind it.
