A4 Brake Problem
Old Jan 29, 1999 | 09:08 AM
BretPowers
Guest
Posts: n/a
Default A4 Brake Problem
Audi warns of possible brake problems in A4 model <br> <br>INGOLSTADT, Germany (AFX) -- Audi AG warned drivers of its A4 model that they may encounter brake problems due to salt on roads.<p>Audi has received about 60 complaints from Germany since Christmas, Udo Ruegheimer, an Audi spokesman said.<p>The salt leaves a "sticky residue" on the brakes which prevents them from functioning properly when they are not used for long periods of time -- when exiting a garage, or after lengthy travel on highways -- he said.<p>The residue is eliminated once the brakes are used, he said.<p>He said no accidents have been reported to date as a result of the malfunction.
Old Jan 29, 1999 | 10:50 AM
Ash
Guest
Posts: n/a
Default Hmmm........
Now would this explain the "poor braking performance" when it's wet out? Is it possible that the performance is a result of the salt that's in the water and not the water itself? Any ideas?<p>-Ash<br>98.5 1.8TQMS
Old Jan 29, 1999 | 12:46 PM
Darryl W
Guest
Posts: n/a
Default Well, . . .
It's very wet today in NE texas, and I noticed a drop in brake performance over the course of my 11 mi drive to work. I'm quite sure there's no salt on the roads down here, so I don't think this is the reason. Honestly, I was very disappointed. The brakes were there when I used a lot of pressure, but the fine control I am accustomed to was not there when using light pressure.<p>Darryl <br>98.5 1.8T qmsb
Old Jan 29, 1999 | 01:10 PM
Kevin M
Guest
Posts: n/a
Default Re: A4 Brake Problem
Occasionally I have noticed reduced braking performance, when I have my 17" rims installed and it is raining. I have not experienced this problem with the stock 15" rims which I mount in the winter time (Thanksgiving to Memorial Day).<p>Could this be the larger rims allow moisture to reach the brake pads????? and affect their stopping characteristics
Old Jan 29, 1999 | 01:47 PM
PhilJ
Guest
Posts: n/a
Default This bulletin is due to SALT on the roads, NOT rain...
Braking of of course affected by water. Any brakes will be affected because it interferes with the contact between the pad and the rotor.<p>This particular bulletin warns about SALT on the roads. Like when salt is used to reduce the amount of ice/snow on the roads. I'd expect people in the NorthEast or Midwest, or Colorado, or Canada to be experiencing these kinds of problems...<p>-Phil<br>
Old Jan 29, 1999 | 06:53 PM
Brake Doctor
Guest
Posts: n/a
Default There is an official factory fix........
Kit# 8D0 698 998<p>Contains larger brake splash shields. The change will be done if there is a complaint of loss of braking in wet, slushy, dirty or salty conditions.<p>See your dealer.
DavidRD
Audi A3 / S3 / RS 3
Dec 7, 2000 01:54 AM
NeedInfo
Dec 5, 2000 04:16 PM
PeteP
Dec 2, 1999 03:56 PM
Aaron Nix-Gomez
Jul 6, 1999 07:53 AM
Grizzly
Mar 7, 1999 11:16 PM
