A4 Overheating
Old Feb 6, 2005 | 08:32 AM
kingstona4's Avatar
New Member
Default A4 Overheating
Ok here goes. Myhead gasket on my Subaru blew last week so I am paranoid now. Last week my exhaust started to leak at the flex pipe on my 98 A4 1.8T it has gotten worse but still isnt super loud. But this morning my car overheats whenever i drive it on the road. In the driveway the car will run for 30 minutes get up to 90 degrees and stay there. I have lots of heat, the coolant is clear and pink like it should be, the upper rad hose gets nice and hot...Could the exhaust leak be causing the turbo to overheat?
PLEASE HELP!!!
Old Feb 6, 2005 | 08:40 AM
quattrokiwi's Avatar
Member
Default Re: A4 Overheating
Check to see if the lower rad hose gets hot, if not, it could be the thermostat stuck closed
Old Feb 6, 2005 | 08:44 AM
Ritz's Avatar
Default Yeah, I'd think it's the thermostat or...
bad waterpump...or blockage in the cooling system. Are you losing any coolant?
Cheers,
Old Feb 6, 2005 | 08:45 AM
kingstona4's Avatar
New Member
Default Re: Yeah, I'd think it's the thermostat or...
No..there is no coolant loss in the system.
I am going to go out and check the lower rad hose a little later..
And pressure doesnt build up quickly in the expansion bottle like a head gasket problem would inicate
Old Feb 6, 2005 | 09:02 AM
ModifiedA4's Avatar
Banned
Default huh? 90degrees what? C, F?
the thermostat opens at 87C. so 90C is normal.
and 90F obviously is waaay too COLD.
is the coolant temp needle vertical?
Old Feb 6, 2005 | 09:06 AM
kingstona4's Avatar
New Member
Default Re: huh? 90degrees what? C, F?
yeah...90 Celius
straight up and down...
Old Feb 6, 2005 | 09:29 AM
Phil type 951's Avatar
Default how many miles on your a4?
if it has more then 60k and has not had the TB Waterpump tsat you need to have it done. you gave us no freakin info about the car so i cant really say anything else.
Old Feb 6, 2005 | 09:32 AM
kingstona4's Avatar
New Member
Default Re: how many miles on your a4?
165000 km
no the water pump hasnt been replaced..it is completey stock.
 Pouria Savadkouei
 Michael S. Palmer
Old Feb 6, 2005 | 10:14 AM
Default well If I were you get the water pump tb and thermo replaced asap
if the timing belt tensioner fails your motor will be toast. please search the archive and see that this happends to a4s all the time.
If I am correct to assume you have the 1.8t motor then you are over 10k miles past the factory recommendation and about 40k pest what most people on this board recomend for this service.
it will cost about 600 bucks to have it done with 200 of that money for parts. if you cant pay that I wouild sell the car today. many people do the work themself but unless you feel confident working on your car I would not try it.
I'm not trying to me rude but you are on borrowed time as it is. be glad the water pump or t-stat failed before the tb let go or you would be buying a new engine.
here is a link to the 1.8t 20v motor timing belt info. if you diy buy the bentily repair manual
http://www.bentleypublishers.com/product.htm?code=a40
it can be found cheaper then this was the first link i saw.<ul><li><a href="http://www.20v.org/20v/belts.htm">http://www.20v.org/20v/belts.htm</a</li></ul>
Old Feb 6, 2005 | 11:41 AM
ModifiedA4's Avatar
Banned
its NOT overheating.
