ABS?
Old Apr 22, 2007 | 11:25 PM
coaxial's Avatar
Default ABS?
I have a 2000 A4 1.8t At first the ABS light would come on solid with the flashing brake light intermittently. Now it just comes on every-time I start the car. Talked to the mechanic he said it was the ABS module for sure, without plugging anything into the car. Could it be any other sensor or anything? Just would like to replace the cheaper parts first before the actual module itself.
Old Apr 22, 2007 | 11:28 PM
Nate (ETKA+Scumbag)'s Avatar
Keeper of the Cash
Tech Guru
Default Start by finding a new mechanic. Then find a mechanic that will plug in their VAG-COM
and pull the codes.
Old Apr 23, 2007 | 02:55 AM
4Driver4's Avatar
Tech Guru
Tech Guru
Meh. He's probably right, but it certainly wouldn't hurt to check it.
Old Apr 23, 2007 | 04:19 AM
Kris Hansen's Avatar
Head Cat Herder
25 Year Member
Or just bring it to Nate, because he knows everything better than you. =)
Old Apr 23, 2007 | 04:23 AM
Head Cat Herder
25 Year Member
Default 99% of the time it IS the ABS module that's gone out in these cases...
You do realize that people knew how to fix cars before computers, right? =)
Depending on what kind of scanner the guy has, he won't be able to read the ABS computer anyway. I believe only a VAG 1552 etc, or VAG COM can access that control module. And, if the ABS controller is truly bunk, no scanner will be able to communicate with it, or the engine module, till you unplug the ABS controller. Just so you know.
Old Apr 23, 2007 | 05:57 AM
BigEd's Avatar
Member
Default He might be right. The way I understand, if there's a faulty ABS sensor, you'll get the warning
light not at startup but after driving off (that's when sensor info is being read/analyzed by the ABS module).
However, if, as in your case, the light comes on immediately after you start the car, it is more than likely the ABS module itself that's faulty.
Old Apr 23, 2007 | 09:23 AM
Keeper of the Cash
Tech Guru
Hey, my time is worth a six-pack and I'll even scan the whole car!
MrAvionics
9
Mar 21, 2016 01:26 PM
polarisrmk
Jul 10, 2009 04:21 PM
Omega Supreme
May 18, 2008 02:59 AM
miruspr
Aug 5, 2005 09:51 AM
