ABS Light
Old May 17, 2009 | 10:22 PM
99Quattro's Avatar
Default ABS Light
Hey There, I am new to the site and I had a question, I have a 99' a4 quattro with just about 115k i just recently had a service done and after that my abs light came on, I took it into the dealer where they ran a scan and though the lights on, its not throwing a code, but I can tell the back portion of the abs is not working, anybody have any ideas thanks
Old May 18, 2009 | 10:27 AM
4Driver4's Avatar
Tech Guru
Tech Guru
Unpossible. If the light is on, there is a code stored.
Old May 18, 2009 | 12:14 PM
Kris Hansen's Avatar
Head Cat Herder
25 Year Member
2nd.
Old May 18, 2009 | 12:44 PM
99Quattro's Avatar
And that is what I tried to explain to the "Certified Tech" at the flow dealership, no light = no prob, light = prob, so not only do I not have a functional abs, but I got charged for some lame ****, they recommended a abs module, which is bogus sense its $1750 any ideas would be great, perhaps checking the sensors ? the breaks are do for replacing maybe that can be a prob
Old May 18, 2009 | 12:52 PM
viceprp's Avatar
my abs light is on .. Dealer says $400 to get a new one. Module Master will do it for right around $150 I believe. You'll have to send it in but beats throwin out all that money.
Old May 18, 2009 | 03:31 PM
4Driver4's Avatar
Tech Guru
Tech Guru
First of all, please post your responses in the correct place within the thread. Check out threaded view if you do not understand.
Second, they probably could not connect to the module to get any codes. You need to get someone with VAG-COM to read it. If you feel like rolling the dice send the unit out for rebuild to Module Master or BBA Reman (a good bet). Worn "breaks" do not cause ABS problems, and issues with sensors throw codes.
Old May 19, 2009 | 03:29 AM
Ray Khan's Avatar
and a 5 year warranty from Module Master. I just had them do mine.
Old May 19, 2009 | 04:03 PM
k0mpresd's Avatar
where in nc are you? im in greensboro. bring it by my house and ill scan it.
99Quattro
Brakes Discussion
May 17, 2009 10:13 PM
A4F4T
Mar 19, 2007 11:57 AM
S4-Fireblade
Audi Original "S" Cars
Apr 15, 2006 09:10 PM
camikazi2k
Mar 5, 2006 01:29 PM
chitown-silver-s4
Jun 11, 2003 01:50 PM
