ABS problems
Old Oct 21, 2005 | 08:08 AM
Nova Scotia A4's Avatar
New Member
Default ABS problems
My ABS seems to kick in at low/slow breaking speeds and I figured it was one of the ABS speed sensors. Took it to a shop to day and did some real time tests and none of the sensors showed anything unusually and all wheels showed to be moving at the same speed. I'm asumming that this means a bad ABS speed sensor can be eliminated.
So I'm now wondering if it is the ABS pump or ABS module. Is there any way to test to see if that is the cause? Any other suggestions?
Thanks in adavance.
Ian
Old Oct 21, 2005 | 08:11 AM
BigEd's Avatar
Member
Default Some info
<ul><li><a href="http://search.audiworld.com/index.html?q=abs+kicks+in+at+low+speeds&amp;u=&amp ;s=all&amp;cat=010001&amp;db=1999-01-01&amp;de=2005-10-21">here</a></li></ul>
Old Oct 21, 2005 | 08:29 AM
jguthrie's Avatar
Did you get the abs to kick in during the test?
Old Oct 21, 2005 | 08:40 AM
New Member
Yeah, and nothing showed up on the lap top
Old Oct 21, 2005 | 09:53 AM
jguthrie's Avatar
Default Removing the sensors and cleaning them would be the cheapest solution
but it doesn't sound like that will help. Worth a try anyways.
Old Oct 21, 2005 | 11:25 AM
New Member
Default I tried pulling one out, but it didnt want to move, and hints?
Do they just pull straight out, any twisting or c-clips or anything? 96 a4 2.8qm
THanks
Old Oct 21, 2005 | 11:57 AM
a4avant99's Avatar
Default Be careful to not damage the sensor when pulling out.
I damaged one by turning it using a wrench (too firm to move it by hand).
Old Oct 21, 2005 | 02:32 PM
jguthrie's Avatar
Default I couldn't get mine out, but I heard
spraying it with penetrant works.
GIAudi
Apr 23, 2010 11:48 AM
blackultra
Dec 29, 2009 12:16 PM
Sir Shnike
VAG-COM Discussion
Oct 10, 2006 05:15 AM
Nova Scotia A4
12v V6 Discussion
Oct 24, 2005 01:52 PM
EvanUrS4
May 11, 2005 09:03 AM
