AC blower problem
Hi guys, my a4 2010 AcC blower working during the summer months but dead once the weather is cold, is this likely to be the thermostat? Any ideas please
Doug
As for refilling, I bought a refill kit and did it myself. If you go this route, check to make sure the pressure is in the Blue (good) area and not low.
As for winter vs summer, if you think about it, if the ambient temperature is significantly lower than the inside temp and you are trying to lower the inside temp, all it has to do is blow cold outside air in to cool your cabin. As it gets hotter outside, the difference between outside temp and inside temp is closer so the system needs the A/C to cool the interior. This is just a theory and may not be how the actual system works.
Doug
