Acceleration
Old Sep 23, 2005 | 09:02 AM
bruther's Avatar
New Member
Default Acceleration
Hi all,
I just had my timing belt replaced ( not including new valves, head and everything else). But once I got my car back my car is significantly slower off the start. Sometimes when starting from a dead stop it will almost stall or will be very slow to accelerate. I tried tightning the throttel cable a little which helped but I need to know some other things I can check or do to get this thing going a little better. It seems to do alright in acceleration at higher speeds(though not as fast as before).
Since having the timing belt put in I had to replace the ignition control unit. Right after I put the ignition control unit in it was accelerating much better but after about 2 weeks it went back to being very slow off the start. I'm not chipped at all and haven't done much else with the engine. I did change the normal stuff, plugs, air filter etc.... I'm thinkgin of taking off my throttle body this weekend and cleaning that or having all my lines pressurized( I'm not sure if that will help me out). If anyone has some good suggestions I'm all ears.
Thanks
my car is 99 A4 1.8T Quattro<ul><li><a href="http://www.cardomain.com/ride/459863">http://www.cardomain.com/ride/459863</a</li></ul>
Old Sep 23, 2005 | 09:05 AM
Kris Hansen's Avatar
Head Cat Herder
25 Year Member
Sounds like they got the timing screwed up. Take it back.
Old Sep 23, 2005 | 09:24 AM
rookie18's Avatar
Default Car domain comment
Unless you swapped out your interior it is leatherette (i.e. vinyl) and not leather.
I'll 2nd what Kris said. It sounds like your timing is screwed up.
Old Sep 23, 2005 | 10:10 AM
bruther's Avatar
New Member
Default Re: Car domain comment
Ok ....your a lot of help
Old Sep 23, 2005 | 10:51 AM
rookie18's Avatar
Default Like I said, your timing is probably off.
Either bring it back to the shop or check it for your self. What more do you need to know?
Old Sep 23, 2005 | 11:17 AM
bruther's Avatar
New Member
I was referring to the car domain comment. eom
Old Sep 23, 2005 | 11:54 AM
rookie18's Avatar
Default Didn't realize that you were so sensitive about that.
Sorry. Don't worry you are not the first or last to make that mistake.
oehrwein
Jul 20, 2013 09:58 AM
fasttrackfab
1.8T Discussion
Jun 25, 2008 11:18 AM
Masisoar
Aug 30, 2006 08:34 AM
cookiemonster
Mar 4, 2006 01:27 PM
the director
Jun 26, 2004 08:46 AM
