Adding an amplifier to your A4
Old Feb 14, 2001 | 02:51 PM
yrrkoon's Avatar
New Member
Default Adding an amplifier to your A4
I'm going to be adding an amp, crossover, and sub to my 2001 A4. Has anyone mounted any amps in their A4 yet? Where did you mount them? Got pics? I haven't looked yet if anything will fit down underneath with the spare.
Gerald
Old Feb 14, 2001 | 02:58 PM
aktif8's Avatar
Default i went ghetto and mounted my rockford on the seatback
it looks fine, and cooling is great. i held down my 2 12's with a luggage strap wrapped around the box, strapped to the cargo net mounts.
keith
Old Feb 14, 2001 | 03:00 PM
GreekTTCharlie's Avatar
what kind of subs you got...and what amp (how much power) i'm buying subs tomorrow!!!
Old Feb 14, 2001 | 03:02 PM
aktif8's Avatar
Default 250a2 bridged (pushes about 500w) to 2 mtx 6000 12s.
make sure you stuff some rags in between the bottom part of the rear deck and the top part..it'll stop the rattling. you'll see what i mean once you take a look.
keith
Old Feb 14, 2001 | 03:03 PM
D.Ross's Avatar
Senior Member
which one's did you decide on? Still set on JL's?
aktif8's Avatar
how did you mount the fogs? i want to get a set, but i'm scared about the mounting..
Old Feb 14, 2001 | 03:05 PM
Default i don't know. I know a guy with a stereo shop that will give me
two 12" Alpine Type S subs in a box for $300.00, but the amp i'd need to run them is MADD expensive.
Old Feb 14, 2001 | 03:06 PM
Jus Plain Snoopy's Avatar
Senior Member
Default Has anyone heard anything about this sub?
Max Power did a snippet of a review on it, and it sounded like they liked it.
<a href="http://www.crutchfield.com/cgi-bin/S-2FFpK33rPdu/ProdView.asp?s=0&c=3&g=51000&I=108BASSLIN&o=M&a=0" target="_top">Infinity Kappa Basslink</a>
 Michael S. Palmer
Old Feb 14, 2001 | 03:07 PM
Default they were pretty easy to mount. I actually cut the grill inserts myself, but
you can always buy the grill inserts from an Audi dealership for like $20.00 that have the holes already in them (from a newer A4).
I'd say go for it! They work good.
Old Feb 14, 2001 | 03:51 PM
RKA's Avatar
RKA
AudiWorld Uber User
Default Nobody has ever added an amp to an A4.
:-) j/k
I've got mine mounted upside down, secured to the rear deck. The amp is only 1.5" high, so it's pretty well hidden up there, you have to bend down into the trunk and look up to get a good view.
It's not a hot running amp, and I'm running it well within it's limitations, so heat hasn't proven to be an issue. Some amps, or configs will not allow heat to escape properly, so be careful doing this.
As for the spare tire well, there isn't a lot of room down there due to the full size spare. If you can locate a donut from a junkyard, you might be in business (of course the *real* fanatics will remove the tire altogether and get a can of fix-a-flat).
