Adding little value
So, the Miata has been out of storage for about a month now, and the A4 hasn't turned a wheel since. Thinking of putting the A4 away to get a parking space back.
With storing the Miata, the gas tank is topped, the tires are pressured to 40 psi, the ECU fuse is removed, and the cylinders are oiled, by adding a tablespoon and turning the engine on the starter motor (sans ecu & spark plugs, obviuosly), then finally the battery is removed.
Is there any other thing I should or possibly should not do to the A4 before putting it away?
flames on why the A4 shouldn't be substituted are not necessary, thanks.
Tim
