AEB Misfire
Changed the plugs, and the valve cover gasket... Cylinder 2 Misfire.
Switch Coil pack 2 with Coil pack 1... Cylinder 2 Misfire...
I'm not very familiar with an AEB engine and I know they have an ICM (Ignition Control Module) on top of the airbox.
Could this be the culprit of this misfire (or not firing at all) error?
Note: After changing the Valve cover gasket and the plugs, it misfired right away. I had past experience that if oil is leaking thru a cylinder, it would take some time before it will start misfiring again.
Thanks in advance for your time!
I called ECS tuning since they carry both Bosch and the Huco ICM. They told me that since I have the Bosch, I should get the Bosch and the Huco will not work.
True or False?
