airconditioning problem
Old Aug 6, 2008 | 08:51 AM
marlac's Avatar
New Member
Default airconditioning problem
My AC went out. I was driving, hit a large pot hole and drive up to a red light. At the red light my car began to idle low and eventually stalled out. When I turned the ignition to restart the car I heard a a loud pinging.
The compressor can spin freely, but the a/c compressor clutch will not engage. The fault codes I am getting from channel 52 are B1 (engine speed less than 200-500) and D1 (engine speed greater than 6000).
Could the RPM sensor be faulty? If so how could I test it and where is it located? Bentyly said to test the OHm reading. The OHms appeared to be fine. I also tried to jump start the compressor..this failed. It appears the a/c compressor is not getting a current??? WHat could cause this????
Old Aug 6, 2008 | 10:10 AM
marlac's Avatar
New Member
Default Re: airconditioning problem
I forgot to mention that I could start the car only after I turned off the AC. Now the car starts and runs fine, just the AC won't work.
clancy
Sep 5, 2016 11:31 AM
Scubasteeve
Aug 10, 2009 08:33 PM
Eiki
Apr 24, 2008 08:51 AM
A-U-D-I 23
Audi 100 / A6 (C4 Platform)
Sep 14, 2007 02:28 PM
omar1956
Jun 13, 2006 01:26 PM
