alignment
Old Feb 13, 2004 | 12:59 PM
nizmosx's Avatar
Default alignment
i have installed coilovers and some 18by8 inch wheels and have not yet gotten an alignment but things seem very straight. no camber problems. but do you think i should get one done and would handling get beter or what not. or are they just done for tire wear. thanks in advance'this is the first time i couldnt afford an alignemt but those two parts emptied my wallet fastolla.
Old Feb 13, 2004 | 01:08 PM
SilverA4Fun's Avatar
Default Typically a 1"+ drop will require a camber adj, unless you want to wear out your tires fast...
toe-in and track can be less effected by suspension changes, but should still be checked. A $100+ alignment check is a safety net instead of $800 in new tires
Old Feb 13, 2004 | 01:11 PM
JAFO's Avatar
there is no way to adjust the camber on an A4/B5!
Old Feb 13, 2004 | 01:22 PM
A4X4's Avatar
then how was mine corrected today?
Old Feb 13, 2004 | 01:28 PM
Shep 1.8T's Avatar
Member
Default exaclty.. same problem I ran into
but it may be okay still, there is some flexibility built into it, the question is how much?
Old Feb 13, 2004 | 01:29 PM
Silver Streakin''s Avatar
Member
*ding*
Old Feb 13, 2004 | 01:41 PM
A4X4's Avatar
Default ....hrmf
the guy at the shop told me that they were way off and he adjusted them to within factory tolorances for camber and toe in...since I'm about to go pick the car up from an alignment, what might I ask?
Old Feb 13, 2004 | 01:45 PM
Yippers®'s Avatar
Member
Default Ask for a print out of before and after. The rear camber has some adjustment and the front can be
moved to split the camber between the two sides.
 Michael S. Palmer
Old Feb 13, 2004 | 06:45 PM
AUDIocee's Avatar
Default Re: it wasnt.
I just called my audi dealer, they said $200 to get a wheel alignment, including a camber adjustment. I asked them if they re-align the subframe for the camber.. they said no, they drill out the strut bolts to allow for adjustment.
My current camber is:
-2.1 LF / -1.0 RF
-2.4 LR / -1.1 RR
This is after a H&R Race/Bilstein install.
If you do a search, there are adjustable control arm kits out there for something like 500 buckaroos...
Old Feb 13, 2004 | 07:35 PM
JAFO's Avatar
Default cool!
i'll see if my dealer will do this. i didn't think audi recomended this!
