alignment...
Old Feb 19, 2005 | 06:54 AM
Audi902's Avatar
New Member
Default alignment...
after having new suspension put in the car has really bad cross camber causing the car to pull. i've tried suggesting to a shop that the cross camber can be adjusted by moving the subframe, but i was told it's just making it worse? nothing is broken on the car. is the shop just dumb? should i take it to the dealership?
Old Feb 19, 2005 | 07:26 AM
iammatt's Avatar
Default ask your local aw forum where to go...
theres a good tire shop in boulder that does them for $50.
Old Feb 19, 2005 | 07:40 AM
Audi902's Avatar
New Member
will do. tried a few local places, but they won't touch the subframe =\
Old Feb 19, 2005 | 08:44 AM
JAFO's Avatar
Default are you sure the springs are in correctly?...
wheel well heights should be within 0.125". i took mine to ntb and lowered 1.3" my camber was still within specs.
Old Feb 19, 2005 | 08:56 AM
Audi902's Avatar
New Member
Default haven't check that yet....but it doesn't look lopsided
If it makes ne difference I had race springs with koni sport shocks put in. i'm pretty low.
Old Feb 19, 2005 | 04:52 PM
JAFO's Avatar
Default what are your camber readings?....
left and right. if they were the same before lowering they should still be the same now without moving the subframe. being that low i'd consider adjustable upper arms.
Old Feb 19, 2005 | 06:47 PM
Audi902's Avatar
New Member
Default camber readings
-2.5 (left)
-.90 (right)
it definately wasn't like this before the install. the car was aligned a few months ago and was tracking perfect. Do you think trying to adjust the subframe is a lost cause? I'd like to get away with just a cross camber balance for now if I can.
i've searched and found that there are a few different options as far as adjustable upper control arms. is there one that you recommend over another?
Old Feb 19, 2005 | 08:46 PM
JAFO's Avatar
Default cpp stainless steel one seem to be the best....
especially if you live where they have winter. most places don't like to adj. the subframe. if you deside this is your only course then a dealer is your best bet.
 Michael S. Palmer
am_ver
36
Dec 3, 2011 08:31 AM
Audi_in_Van
17
Jun 29, 2007 12:27 PM
rageman
20
Jul 21, 2006 09:17 AM
Audi902
Florida Discussion
Feb 20, 2005 05:17 AM
superv
Feb 15, 2005 11:12 AM
