alignment problems and recal question?
if the car pulls then you need an alignment... those are about $180 at the stealership. Looks like you are a noob by your AID.
New tie rod ends are available from ecs you can buy a pair of them and put em in... but you will need an alignment.
The only adjustment on the B5 is done with the tie rods. There is no camber adjustment unless you buy adjustable control arms.<ul><li><a href="http://www.ecstuning.com">http://www.ecstuning.com</a</li></ul>
