Another broken Ignition Module
Old Aug 30, 2003 | 12:18 AM
Lithium's Avatar
New Member
Default Another broken Ignition Module
Two days ago, my 99.5 A4 started idling rough and then, a few seconds later, died with the flashing CEL light. I hooked up my VAG-COM and saw entries for cylinder 2 misfires. So, I replaced the Denso Iridium sparkplugs that I had in there with new Bosch OEM's. Still had misfires on cylinder 2. Then, after more audiworld searching, I swapped coil packs 2 and 3, and saw that the misfires DIDN'T follow the coil pack. Today, I got the Ignition Module replacement and everything just went back to normal! (actually a little better with the new sparkplugs) I'm soooo relived! Audiworld rocks!
Old Aug 30, 2003 | 05:46 AM
ArandA4's Avatar
Did you buy the 4D0 part or the 8D0 part?
Old Aug 30, 2003 | 12:31 PM
Lithium's Avatar
New Member
Huco 4D0 for $130
Old Aug 30, 2003 | 01:06 PM
A4 Pilot's Avatar
Default I had the same problem (also cyl. 2)..New ignition module solved it too.
Also replaced my ABS controller this week. (it's been an expensive week!). I now need a new front bumper / valence to replace the one that's been torn off...
jedblack
9
Oct 17, 2011 12:22 AM
Euromagination
Jan 27, 2005 01:50 PM
LarryF_in_Ca
May 18, 2004 06:04 AM
tppatron
Mar 18, 2004 07:41 AM
Jack Wang
Nov 6, 2002 09:59 PM
