Any pointers on bleeding Boxster calipers?
Old May 2, 2006 | 08:08 AM
nunya's Avatar
Default Any pointers on bleeding Boxster calipers?
I bled the front, still had air in them. Then I bled the rear, still air. Then i bled the front again, still air. I have talked to a couple people that say gravity bleeding is the way to go. What do yall recommend?
--dillon
Old May 2, 2006 | 08:11 AM
Sal R.'s Avatar
Make sure you have a good seal b/w the hose and bleed screw.
Old May 2, 2006 | 08:18 AM
ScratchRob13's Avatar
RR,RL,FR,FL in that order, with a helper
Old May 2, 2006 | 08:30 AM
Mr. Mom's Avatar
AudiWorld Expert
Default get speed bleeders or pressure bleeder (motiv)
either works great
Old May 2, 2006 | 08:45 AM
Mr. Mom's Avatar
AudiWorld Expert
Default speed bleeders
<ul><li><a href="http://www.speedbleeder.com/">http://www.speedbleeder.com/</a</li></ul>
Old May 2, 2006 | 08:47 AM
Mr. Mom's Avatar
AudiWorld Expert
Default Motiv pressure bleeder
<ul><li><a href="http://www.motiveproducts.com/">http://www.motiveproducts.com/</a</li></ul>
Old May 2, 2006 | 09:09 AM
manualAvant's Avatar
clutch last!
Old May 2, 2006 | 09:17 AM
nunya's Avatar
Default Hmm thats strange cause the clutch works fine....
And i bled it first. This is all after an engine swap BTW.
--dillon
Old May 2, 2006 | 09:37 AM
everything I've seen people post about say clutch is last. Not to say it won't work...
Old May 2, 2006 | 01:06 PM
Carson (K03x2)'s Avatar
Default When you bleed the front boxster calipers
start with the inner bleed screw on the right front, then the outer, then the inner on the left front followed by the outer.
