Any tips for getting a stuck abs sensor to come out?
Old Apr 1, 2006 | 10:55 AM
JeffPetrone's Avatar
New Member
Old Apr 1, 2006 | 11:13 AM
xdriver's Avatar
Hit it with some pb blaster and give it some time
Old Apr 1, 2006 | 11:38 AM
New Member
Whats pb blaster? Autozone carry it?
Old Apr 1, 2006 | 11:43 AM
RS41AB's Avatar
Banned
Default If you're doing your rear bearings, don't take it out if it's stuck.
Not worth risking the breakage.
Lift off rear sear lower cushion, unplug sensor from connector, pull through floorboard, remove with rest of hub.
To put it back in just take a coathanger and slide it through the open hole in the floor, attach sensor, and pull back through. Put rubber plug back in place.
I'm not sure about the fronts.
Done. Those things are too expensive to break.
xdriver's Avatar
Default I bought a can at my autozone in Mass. It is "like" wd40 but it is what you want to use.
I forget exactly but I think wd40 displaces moisture and lubricates. pb blaster is a penetrating formula that actually breaks down the rust.
Old Apr 1, 2006 | 12:46 PM
BSK auf Arbeit's Avatar
FAQ Author
aerokroil is my recommendation
Old Apr 1, 2006 | 12:55 PM
gh0st's Avatar
the WD stands for Water Displacement
vtraudt
Jun 29, 2014 05:36 AM
Pupek
1.8T Discussion
Mar 16, 2009 05:37 AM
Speedy72t
Sep 5, 2005 07:09 PM
AudiLurker
Feb 20, 2005 03:56 AM
Mitaka
Nov 30, 2004 06:13 PM
