Anyone ever have a Speedometer fail intermitantly?
Old Aug 18, 2003 | 04:32 PM
hazz0003's Avatar
New Member
Default Anyone ever have a Speedometer fail intermitantly?
I have had the speedometer fail 3x now while driving. I bought my car Second Hand with 54 K miles so it has no warrenty. I am thinking this is a sensor or connection issue. My Chilton's Manual is completely worthless at providing any info on the matter. Anyone ever done a sensor replacement or have a decent reference?
Thanks,
hazz0003
2000 A4 Avant 1.8T Q
Old Aug 18, 2003 | 05:18 PM
SlipStreamX's Avatar
Member
Did the car fail to log any miles as well?
Old Aug 18, 2003 | 05:22 PM
hazz0003's Avatar
New Member
Default Yes.. trip odometer remained at 0 for the trip home.
yes. Trip odometer remained at 0 for the trip home or until the speedometer poped back up.
Old Aug 18, 2003 | 05:24 PM
Mat Indukts Lambos's Avatar
Banned
Default Certain symptoms mean different things.....more
If it works for a while, but starts acting real wierd at higher speeds, it's usually the sensor ring inside the trans. This involves some minor trans disassembly, but the whole trans doesn't actually need to come out of the car. The actual speed sensor is easy to swap, but is rarely the fix.
My track car does that over 120 mph, then doesn't start working right until I'm down around 80. I just live with it.
Old Aug 18, 2003 | 05:33 PM
AudiAddict B7's Avatar
Junior Member
Happened to me, worse when wet, they replaced the speedo sendor on the gearbox under warranty
Old Aug 18, 2003 | 11:51 PM
Member
I wonder what it is, cuz mine hasn't popped back on and no speedometer or miles.. I'll keep U posted
Old Aug 21, 2003 | 09:50 PM
hazz0003's Avatar
New Member
Default Re: Happened to me, worse when wet, they replaced the speedo sendor on the gearbox under warranty
I did notice a pattern to the Speedometer failing. The "Worse when wet" comment tipped me off. Sure enough, it rained the day after this was posted. Guess what?, .5 miles out of the driveway, my speedometer dropped to zero. When conditions were dry about 9 hours later it worked fine. All of the times it has failed have been in very humid, raining, or sub dew-point conditions. Moisture must be causing a short or an erronous sensor reading.
Apexmaster
Jul 13, 2017 10:36 AM
OMP
Jun 27, 2015 11:16 PM
kermac
Aug 15, 2008 01:51 PM
victor army
Apr 8, 2007 08:54 PM
Mikael Palander
Jan 6, 2007 06:04 AM
