APR chip problems?
My guess is something else is wrong with your car. Things to look for: Boost leaks (loose clamps), and vacuum leaks. Has maintenance been performed on your car (clean air filter, good spark plugs, etc. Have you hooked up your car to vag.com to look for error codes?
It doesn't do this all the time. Mainly 2nd gear, 4000 rpm, when it's really pulling under heavy acceleration. Maybe it's blowing a connection, but if this were the case, would I still be able to reach max. boost (17psi w/the APR chip?) at other times?
But if it does show a problem in stock, I have other problems.
Running the turbo with higher boost puts greater demands on a LOT of parts in the engine bay...not just the turbo. A boost leak could be present at 14 psi, but disappear entirely below 10 psi. A vacuum leak could cause major issues at 14 psi, where at 7 psi it's effects are hard to notice. A clogged air filter may work fine when you're running 7 psi, however at 14, the engine might not be getting enough airflow. So you can see, it's not necessarily the turbo...in fact, if you're getting 17 psi of boost, chances are very good that the turbo is fine.
