Audi a4 2.8 30v engine code?
Old Nov 6, 2010 | 07:29 PM
eliastfk's Avatar
Default Audi a4 2.8 30v engine code?
I have a 1998 audi a4 quattro 2.8 30v, i would like to know how to tell which 2.8 i have because i know one of the codes is aha and i dont know what the other alternative is, but anyway, i would just like to know ho to tell if i have the aha or not.
Old Nov 7, 2010 | 04:00 AM
Old Dog's Avatar
The other is ATQ. Here is the link where I found it which goes on to say where to find the codes:
https://www.audiworld.com/forums/sho...d.php?t=288351
Old Nov 7, 2010 | 06:36 AM
eliastfk's Avatar
those entries told me to check the manual and under the hood near the emissions sticker, i did both but still no luck, isnt there something having to do with the vin numbers?
Old Nov 7, 2010 | 09:35 AM
Old Dog's Avatar
Ok, now when you get a sec have a look to see if there is a sticker in the spare tire compartment that says AHA or ATQ. Failing this eliastfx, I'm afraid I don't have any other suggestions. Sorry .
Old Nov 8, 2010 | 10:38 AM
RobQ's Avatar
Look on the passenger head at the front on the top of the lifting eye.
Old Nov 19, 2010 | 12:27 AM
Harddrive2000's Avatar
ROBQ is right. Thats were you'll see the engine code. Its stamped on the front lifting eye (passenger side of engine)
Old Nov 19, 2010 | 03:08 AM
4Driver4's Avatar
Tech Guru
Tech Guru
Yours is the AHA, but there is an early version of the AHA that is different than the later AHA. In 98 you could have either. Remove the plastic engine covers and look at the PVC system. If there is a plastic vent pipe that goes across behind the coils and connects the two valve covers, you have an early AHA. If the pipe runs from the passenger side across behind the coil pack and to the rear of the car, it is the later more common AHA.
Lumik
VAG-COM Discussion
Feb 10, 2011 11:49 AM
vtraudt
Nov 15, 2010 04:56 AM
IllWil
Mar 28, 2005 01:30 PM
Steve_Ag Arrow
Jan 25, 2004 11:42 AM
TheFez
Jun 25, 2000 02:26 PM
