audi a4 rear door panel removal
Carefully remove the piece, lever it out with a plastic knife.
There should be a screw behind it, I believe it's a torx .
Lift the panel and it should come off . Disconnect the cable holding the door release. Then it should all unplug from there.
If you are replacing speakers you may need to cut the insulation to get access.
