Audi S4 Seat Conversion
Old Dec 26, 2006 | 12:33 PM
sushi_turbo's Avatar
New Member
Default Audi S4 Seat Conversion
Alright so I came across a Craigslist ad for front and rear black leather powered seats from a 2000 S4. I have a 1999.5 Audi A4 1.8T with manual seats. Is it possible to do a complete front and rear swap? How much would I be looking at for labor at a shop?
Btw I'm getting the front and rears for 450, is that a deal as well?
Feedback greatly appreciated, thanks!
Old Dec 26, 2006 | 12:45 PM
s4wood's Avatar
AudiWorld Expert
Default is $450 a deal...depends on the condition of the driver side seat...
It will look the worst of all of them most likely.
Old Dec 26, 2006 | 12:50 PM
Kris Hansen's Avatar
Head Cat Herder
25 Year Member
Default It is possible, I believe it's been done. Try a search, see if you can find it.
If you can, please link it here so I can write it up! =)
Old Dec 26, 2006 | 12:52 PM
andysprague's Avatar
Default The rear seat should drop right in. The passenger's seat might too, but the driver's seat....
will require some fabrication to make it bolt in IIRC.
You might have to do the same for the passenger seat too. I don't remember.
I know I looked at alot of other options (S4 seats, TT seats, etc) before I found a set of A4 sport seats. They are the way to go IMO.
Old Dec 26, 2006 | 12:55 PM
Head Cat Herder
25 Year Member
Default I believe that QFrog confirmed that it's possible with factory parts...
Something to teh effect that the front slider bracket bolts in.. I'll have to see if I can find it.
Old Dec 26, 2006 | 01:38 PM
kennyc's Avatar
Default I did the same research.
1.8t to S4 seats
Rear should is pnp (plug and play)
Front is another story, to install the seat you have to
1. cut off the front seat support
2. drill and thread two holes in the floor to bolt the power seat
3. route power and wire new connectors to the seats.
Old Dec 26, 2006 | 02:12 PM
qfrog Ti20's Avatar
Default yes you can swap manual seats for power seats
it requires carpet cutting and riveted inserts to be installed in the floor... also the center rail for the manual seat must be extracted or chopped off. You can also go from power seats to manual seats by welding on a monorail bracket. I've swapped a car both ways and I dont really want to post a whole lot more about it... its a pain in the *** to do IMO... welding is required and special tooling is also required to do it correctly so that the car stands a chance of being safe in an accident.
Old Dec 26, 2006 | 02:52 PM
Head Cat Herder
25 Year Member
More involved than I recall, eh? Thanks Phil!
Old Dec 26, 2006 | 03:00 PM
s4wood's Avatar
AudiWorld Expert
Default What do you know...you act like you work at a dealer or somethin
:-P
Phil, how easy is it to move some heated B6 S4 front seats into a B6 A4 1.8T? I know the passenger seat is manual, so I am guessing that would be the hard side.
Old Dec 26, 2006 | 04:21 PM
QuattrOZZy's Avatar
Default Why swap out Sparco's for S4 stockers??
your sig says u have spearco's and 5 point harneses
unless your unhapy with the sacrifice in comfort, why the heck would you downgrade your seats?
and.... what might be happining to those sparco's?
