Auto Rx question....
Old Jul 26, 2006 | 04:21 AM
Mr. Head's Avatar
Default Auto Rx question....
For those of you that have done this treatment on your A4 how did it do? Have you pulled the valve cover to check out your sludge (if any).
I've been running M1 0-40 since I bought the car at 72,000 miles and am now at 97,000 miles. the PO said that he used M1 since new, but it did not look like it....
At about 94K, I pulled the valve cover to replace the Cam Chain tensioner and the Cams and surrounding parts of the head definately were coated with a layer of sludge.
So I was thinking about doing an Auto Rx treatment just in time for the engines 100,000 mile birthday.
My understanding is that you drain the oil and replace with a filter and Dino Oil and a can of Auto Rx. Drive for 2-3 kmi, and drain the dino, replace the filter and put M1 0-40 back in.
Is that right?
What kind of Dino oil do you recommend?
Where can I get Auto Rx?
What kind of difference has it made in your A4?
TIA
Old Jul 26, 2006 | 04:36 AM
Ray Khan's Avatar
I've just put seafoam in my oil for a hundred or 2 miles before I change it.
Old Jul 26, 2006 | 04:37 AM
NewtsA4's Avatar
Default read reviews at bobistheoilguy ... link for auto-rx in text
<ul><li><a href="http://www.auto-rx.com/pages/applications2.htm">Auto-RX application</a></li></ul>
Old Jul 26, 2006 | 04:48 AM
Mr. Head's Avatar
I seafoamed my car about a month after purchase...didn't seem to do much...
Old Jul 26, 2006 | 05:10 AM
pac1085's Avatar
Default You're doing it wrong!
It's been posted many times, you don't want to run seafoam in your oil like that.
It will just break down some of the sludge and move it around the engine. It evaporates quickly and just re-deposits the sludge.
The proper way to use seafoam in the crankcase (at your next oil change)
Leave old oil &amp; filter in the car.
Put 1/2 can of seafoam in the crankcase.
Run car for approx 10 mins until it gets up to temp.
Drain oil but leave old fiter on.
Put in a few quarts of cheap dino oil (I used 0w-20)
Put in the other half can of seamfoam.
Run car for another 10 minutes or so.
Change oil like normal.
Old Jul 26, 2006 | 05:21 AM
Mirror|rorriM's Avatar
AudiWorld Expert
How does it evaporate? It's a closed system.
Old Jul 26, 2006 | 05:31 AM
ModifiedA4's Avatar
Banned
Default PCV system?
pac is right, seafoam is a volatile solvent, sort of like working with acetone.
Old Jul 26, 2006 | 10:05 AM
EDness's Avatar
Default i did the treatment on my 2 cars...non audi...
it worked well for me, especially on my beater car. It idles smoother, gave me 2 mpg better than before.
When i drain the oil after the treatment, it was pretty dark and thick.
Old Jul 26, 2006 | 10:52 AM
Ray Khan's Avatar
Default my mileage is up considerably as well
new oil? New plugs? different plugs? correct torque on plugs(was likely a little low before without tq wrench? Or seafoam?
Old Jul 26, 2006 | 11:02 AM
EDness's Avatar
Default auto-rx...
i also did seafoam thu the PVC for the beater car. I didn't change the plugs yet, i got other issues with the car i have to deal with before i change the plugs. =(
