B5 A4 2.8 30V 5sp smells like oil no leaks
Travis
-valve cover gaskets
-cam chain tensioner gaskets
Its also worth checking or replacing the pvc in the breather hose(in pic).
Travis
If the pcv/breather hose assembly has not been replaced in the life of the car, you might consider just replacing it.Over time, they get fairly brittle and fill with coking. I replaced ours at 58k and the engine is still dry at 85k.
Since I understand that after 121,000 miles a clutch has got to be close to worn out I started crawling underneath to inspect the car. After noticing that every CV boot is in good condition I have truly began to respect the build quality on this car even more. However, I did notice a bit of drip running down the driver side manifold and onto the lower suspension. It has not hit the ground and I cleanded it off to try and see where it is coming from. Does this sound like a cam chain tensioner gasket? I know what a cam chain tensioner is but it seems this particular gasket location is specific to audi. Could you provide some insight into where the leak originates? Sorry for the highly technical question.
Travis
Not having my factory manual in front of me, but the cam tensioners should be:
-driver's side, towards the back side of the head.
-passenger side, should be located towards the front of the head
Don't quote me though, its been awhile since I've worked on a AHA V6(our 00 is an ATQ motor).
So after our last conversation I am considering changing the cam chain gaskets, positive crank case ventilation (does it run in the back of the cylinders??, I think I found it), and the valve cover gaskets. All because I like driving the car so much. Thanks again.
Travis
