B5 S4 SEATS IN B5 A4 WITH MANUAL HEATED SEATS
Old Nov 22, 2011 | 03:49 PM
GadgetRS4's Avatar
Default B5 S4 SEATS IN B5 A4 WITH MANUAL HEATED SEATS
hey all,
i picked up a b5 s4 interior for my a4 which has black leather manual heated seats. if anyone could chime in i need some help in getting power for the power s4 seats. any and all help would be greatly appreciated. i did some reading up and i know that the 10amp fuse should be changed to 30amp and wanna know the best way to get power to the seats??
thank you
Gadget
Old Nov 22, 2011 | 07:28 PM
AudiMick's Avatar
Originally Posted by GadgetRS4
hey all,
thank you
Gadget
Could you please record this and place it on you-tube, the resulting fire should be spectacular.
The heaters and seat motors should be on separate circuits. If you look at the wiring for the seats there is a pair for the heater, a pair for the seat motors and pair for the seat belt interlock. You new S4 seats will have a pair for the side impact airbag.
No way should you combine them. Changing the fuse without upgrading the rest of the wiring is not a good idea.
Old Nov 23, 2011 | 03:38 AM
adamgt's Avatar
Default I think you're just confused.
You don't need to change the 10A fuse, you will be adding a 30A fuse. I just did this for the first time, it was easier than I expected. The power block under the driver's knee bolster is easy to access, and I grounded to one of the bolts at the front of the seat.
Old Nov 23, 2011 | 05:37 AM
GadgetRS4's Avatar
Default not confused...
im not confused, just no direction.what did u tie the 30a fuse line into? also what color wires on the seat are ground and power and how did u bolt down the seats? also on the passenger side there is only 2 plugs not 3 so what did u do to the passenger as well? again thank u for the input , it is much appreciated!!
Old Nov 23, 2011 | 05:38 AM
GadgetRS4's Avatar
also do u have any pics for reference i could use?
Bodyimager
Jun 6, 2010 09:41 PM
Roque
SoCal Discussion
Apr 21, 2008 02:16 PM
sushi_turbo
NorCal Discussion
16
Jan 17, 2007 10:05 PM
Beemer832
Nov 29, 2006 06:27 AM
alpinab7
Audi Original "S" Cars
22
Oct 25, 2005 04:21 AM
