The On-Board-Computer...
Old Nov 17, 2005 | 05:46 AM
philly101's Avatar
New Member
Default The On-Board-Computer...
My A4 is a 2000 model. For a long time, I had the sign that says, "Service" pop-up on my on-board-computer screen located between the tacho and the speedo, as you all know. I don't go to the dealer for my regular services and check ups; I go to a private place in my area cause they tend not to rip me off (haha ;] ). Anyways, I just want to know if there's a way to make that sign go away. Also, as many other audi owners experienced, my on-board-computer is kinda messed up. It tells me to check my brakes, so I did and there's nothing wrong with it; however, the sign's still there. Should I replace the OBC or get my brakes checked up by an Audi dealer? The screen's also fading away, which seems to be a common problem. The dealer said it would cost me around 600~700 bucks, labor not included. Is it worth it? I need some help. Thanks.
Old Nov 17, 2005 | 05:48 AM
BSK auf Arbeit's Avatar
FAQ Author
Default use the vag com locator and get someone to reset the service interval
and read out some codes as well.
as for the brakes: might be a loose connector
Old Nov 17, 2005 | 07:19 AM
slightly disgruntled's Avatar
Default I think you can do it cheaper... check the tech articles and use the vag locator to find someone...
with a vag tool to help you.<ul><li><a href="http://www.google.com/search?hl=en&amp;q=vag+locator&amp;btnG=Google+Sea rch">click</a></li></ul>
Old Nov 17, 2005 | 08:26 AM
philly101's Avatar
New Member
Thanks a lot. =]
WakeX2
Q7 MK 1 Discussion
9
Jul 8, 2019 10:11 AM
gpj111
S6 / RS6 (C7 Platform) Discussion
16
Feb 14, 2016 07:54 PM
rob1234
Canadian Discussion
Jun 6, 2007 10:51 AM
Mikey L
Jun 30, 2003 02:39 PM
springs n shocks
Jan 19, 2000 08:16 PM
