Boost leak problems????
I have worked on VW's and Audi's for years. I have owned more than one VAG 1.8t vehicle. I cannot find the freaking boost leak on this car! I have checked IC piping. I have replaced a few suspect vac. lines. Swapped DV's. Checked clamps and replaced a few. But, its still there!!!
Now, I would be checking all avenues of the intake track on my bentley CD manual, but I CANNOT USE IT because i have vista!!!!! So I thought someone here might shed some light on my problem. I thought maybe one of the check valves could be allowing boost into the crankcase, but is seems unlikely. Maybe the injector O rings need replaced??? I have noticed a few places that look like they have accumulated blow by on some vac. lines, as well as around the injectors. If anyone has gone through this problem in the past, your help would be appreciated. I know the B6 has a typical boost leak vac. hose problem that was common on the early models, so I thought maybe my car has a similar problem and fix. I want to be able to fully enjoy my car again.
Thanks in advance.
When you lost about 2 psi, which it honestly feels like I have lost (after all these years of working on and owning VW's and Audi's). Did you experience a high pitched whistle under heavy load (ex: WOT)? If I am a little light on gas trying to avoid the whistle, the boost is more responsive. If you push it though, it dogs a bit. Also did you experience noticable lag in normal driving?
Thanks for the help. I checked the waste gate vac. line earlier today, but it seemed to be fine and properly sealed. Might have to look into the WG diaphragm too.
