Brake Caliper Problems
Old Dec 10, 1998 | 09:34 PM
Rod M.
Guest
Posts: n/a
Default Brake Caliper Problems
Question...<p>Has anyone had any difficulties in installing rear brake pads on a 1.8T? I'm trying to replace mine and have been unable to "screw" the piston back into the rear caliper...it seems to turn fine, but it's not retracting Any ideas?<p>Thanks in advance.<p>Rod M.<br>97 1.8T QMS
Old Dec 11, 1998 | 03:11 AM
PeterV
Guest
Posts: n/a
Default Re: Brake Caliper Problems Funny you should ask..
Rod......<br>Guess what I have the same problem. I installed the L&R front Mintex redbox pads as the FAQ recommends all went smoothly. The left rear pad was installed and the piston retracted as described.<br>The RR in another story. I gnarled up a perfectly good pair of needlenose pliers in rotating clockwise about 12 times. The piston rotated smoothly but would not retract one mm. It appears that there may be some<br>I (we) perhaps did not know about in order to get the piston retracted correctly. As you I am hoping for some input in order to have all 4 corners the same. The stock pads are back in the RR.<br>3/4 mintex Pete <br>
Old Dec 11, 1998 | 06:31 AM
PeterV
Guest
Posts: n/a
Default Re: Brake Caliper Problems Perhaps an answer...
Rod,<br>I have just spoken to an experienced Audi tech. He indicated that I (we) need to apply some perssure to the piston as it is turned clockwise. This should do the trick as they say. I'll attempt this later today. I'll post if this process works. <br>PeterV
Old Dec 11, 1998 | 12:44 PM
Cathleen
Guest
Posts: n/a
Default Pete
Is this Pete Voss....PetesA4, QCUSA, pearl A4 2.8qm?<br>
Old Dec 11, 1998 | 01:40 PM
Ray Calvo
Guest
Posts: n/a
Agree with need for pressure application during turning - worked on my old Coupe Quattro (nt).
Old Dec 11, 1998 | 04:33 PM
PeterV
Guest
Posts: n/a
Default Re: Pete
Almost Cathleen QCUSA yes, Pete yes, Voss no, 1.8 TQ auto. Bamboo, An Audi advocate yes. Thank you.<br>Peter Van S.
LuvnhatemyA6
25
May 10, 2007 05:50 AM
gagnu
Nov 18, 2006 05:18 PM
888
Nov 5, 2003 03:17 PM
AVH
Oct 19, 2000 02:24 PM
Andy Hedin
Jan 24, 1999 04:52 AM
