break light problem
Old Apr 25, 2004 | 08:36 PM
husky's Avatar
New Member
Default break light problem
right after I fixed my dead tail light(the one at the bottom) passenger side, the break light on the same side does not work anymore, I tryed to switch bulbs, found there is nothing wrong with the bulb,
Maybe the wire? I didnot touch anything, It works fine before I change the tail light bulb,
any one saw this kind of problem before?
Old Apr 25, 2004 | 08:39 PM
RKA's Avatar
RKA
AudiWorld Uber User
Default I had this problem on a non-Euro car...
turned out I put the bulb in backwards. I removed it, rotated 180 degrees, and reinserted it into the holder...everything was fixed.
Old Apr 25, 2004 | 08:54 PM
husky's Avatar
New Member
those bulbs have +/- order?
Old Apr 26, 2004 | 09:06 AM
Ray Calvo's Avatar
Rest In Peace
Default It's "brake", numnut
Where do people go to school????
I haven't looked at the bulb types, but both are double-filament style (i.e, they are switchable)? Also, make sure it is installed right; dual filament bulbs only install one way. As I remember, accessing these bulb holders is not the easiest thing in the world.
If you feel bulb installation is OK, look down into the bulb socket and see if the base is OK (base contact that hits the center bulb electrical contact). Sometimes this center contact loses it's "springiness" and you don't get good contact with the bulb base. Another idea is to run a piece of sandpaper across the bulb contact.
royclark
33
Jan 24, 2011 01:07 PM
Niketalk1
Q7 MK 1 Discussion
Aug 1, 2009 11:18 AM
closed loop
Audi Original "S" Cars
Nov 6, 2006 08:41 AM
meem
19
Jan 5, 2004 09:10 AM
ex-quattro PETE
Oct 13, 2003 10:37 AM
