Broken cupholder...
Old Jun 22, 2007 | 07:52 PM
77'911's Avatar
Member
Default Broken cupholder...
<center><img src="http://i18.tinypic.com/53idpj5.jpg"></center><p>A complaint was relayed to me that "the cupholder was non-operational", so I hopped to my duty of seeing if I could repair the situation. The wood trim surrounding the holder is a real charmer to remove without damage. Snap-On makes a set of picks that work well for this operation without removing the radio. Only Audi could make a cupholder for over $100. After releasing the two clips that hold it in with a couple screw drivers, the holder popped out. Time to order more parts on Monday. I was hoping to see one for sale in the market place here to no avail. Have a good weekend everybody.
Old Jun 22, 2007 | 09:10 PM
Bobby Kinstle's Avatar
AudiWorld Uber User
25 Year Member
how do you get it out of the dash?
Old Jun 22, 2007 | 09:33 PM
Silver Streakin''s Avatar
Member
it's such a waste of space. I've never used it.
Old Jun 22, 2007 | 09:49 PM
77'911's Avatar
Member
Default a response....
<center><img src="http://i18.tinypic.com/6fio47n.jpg"></center><p>You'll find once you have the trim panel removed, there are two spring clips at the upper right &amp; lefthand corners of the hole in the dash(where the cupholder goes). Just stick a small flat headed screw driver's into each to release them, and you'll be able to pull it right out.
The pic is of the backside of the trim panel you'll need to remove. This way you'll know where the clips are and where to put the stress on for removing the panel. I can't seem to get the other pic I took of the hole in the dash(where the cuphole goes) to host. Email me and I'll send it to you if you need it. Hope this helps.
Old Jun 22, 2007 | 09:58 PM
77'911's Avatar
Member
<center><img src="http://i19.tinypic.com/4yfmcrr.jpg"></center><p>Agreed. Well, lately we've found it comes in handy while waiting for the ferry to come in. The coffee is not too bad at the BC Ferries terminals.
Old Jun 22, 2007 | 10:05 PM
77'911's Avatar
Member
Default pic of the location for cupholder...
<center><img src="http://i10.tinypic.com/660l2bo.jpg"></center><p>Here's the pic. If you look in the upper right &amp; lefthand corner of the hole in the dash(where the cupholder goes), there are 2 spring clips that can be released with flathead screw driver's. Sorry for the poor quality pics, taken quickly. I should have had it centered better.
Old Jun 22, 2007 | 10:07 PM
albertaA4's Avatar
Proudly brewing Starbucks coffee
Old Jun 22, 2007 | 10:22 PM
77'911's Avatar
Member
Default well, not exactly....
They generally have both Starbucks and Salt Spring Island Coffee at the terminals, like Tsawwassen. If your around Vancouver Island , you might try Serious coffee, probably some of the best I've ever had. God help Starbucks if those guys ever franchise in the states.<ul><li><a href="http://saltspringcoffee.com/">http://saltspringcoffee.com/</a</li></ul>
Old Jun 22, 2007 | 10:26 PM
gh0st's Avatar
way better than the ones in my car
Old Jun 22, 2007 | 10:30 PM
albertaA4's Avatar
Thanks for the link, will have to try them next time out.
