Broken Odometer?
Old Aug 7, 2000 | 06:02 PM
scott12v@pghaudi's Avatar
Default Broken Odometer?
I just completed the Aluminun trim modification to my 1996 A4. Everything looks great, but now my odomoter and tripometer aren't working. I checked all the wiring and everything seemed pretty tight, so I'm not sure what I missed. The wierd thing is, if you look at it in very bright sunlight, you can make out the numbers. I can see that the osometer and tripometer are still incrementing, but its extremely hard to make them out. The rest of the instrument cluster is fine.
Thanks for any info.<p>Scott
Old Aug 7, 2000 | 08:41 PM
Kyle Bailey's Avatar
New Member
Default Re: Broken Odometer?
You must have a bad connection to the backlight for the odometer, or your bulb coincidentally burned out while you were doing the mod. Did you remove the instrument panel? I've never had mine out, so I can't help you out. But I have seen several threads regarding bulb replacement. Check the archives.
Kyle
Old Aug 8, 2000 | 02:37 AM
Default Didn't take out the cluster, but you're probably right.
I ordered the Bentley manual so that I'll be able to find out which one of the 1000 wires the backlight actually is.
Thanks.<p>Scott
Old Aug 8, 2000 | 06:33 AM
DaveN's Avatar
Junior Member
Default It is a lamp...
I detailed how to change it up the page, the Bentley will be nice to have around anyway though.
Bad Justin
Audi 100 / A6 (C4 Platform)
10
Aug 13, 2008 05:18 PM
CactusGreen
Sep 23, 2006 06:47 PM
longtimenoob
Mar 11, 2006 04:57 PM
QBits
Jul 27, 2005 11:52 AM
Andy_FL
Jul 2, 2001 09:49 AM
