Bypass Valve install ... help!
Old Jul 23, 2001 | 01:49 PM
g8keepR007's Avatar
Default Bypass Valve install ... help!
<center><img src="http://g8rules.dhs.org/Pics/Newcar/bypassvalve.jpg"></center><p>Ok I know how to get to the valve itself and loosen the bottom clamping ring (circled in blue), but the top one is a real PITA. I can't figure out how to loosen it. I know several people here have installed this and haven't mentioned any real problems, but how do I loosen that top clamp!!! ARG!! (I have it circled in the picture)
Old Jul 23, 2001 | 01:54 PM
WJM's Avatar
WJM
Tech Guru
are these screw clamps or the OEM crimp clamps?
Sal R.'s Avatar
Default Those are pinch clamps...
...you'll need to use pliers or something to pry them open.
Old Jul 23, 2001 | 03:05 PM
WYSIWYG's Avatar
pry it with a small flathead screwdriver
Old Jul 23, 2001 | 06:20 PM
g8keepR007's Avatar
Default Re: Bypass Valve install ... help!
thanks guys.. with your help and also being able to locate another crimp clamp (or whatever you want to call it) near the top of the engine I was able to get it out. Still a PITA.. I wound up just busting it and getting a new clamp that has the flathead tightener (MUCH MUCH easier to work with!!!) Just went on a test drive and it seems fine. Man is that stock valve a piece of s%*@
3Vil_twin
NY / NJ / CT Discussion
Mar 27, 2010 12:37 PM
nwilson1024
Jan 12, 2007 12:38 PM
ouhdeeman
Nov 7, 2004 11:38 AM
FUGLY AUDI
Jul 17, 2003 08:50 AM
