Can someone please explain this code?
I pulled it on saturday... Any information would be appreciated.
FS: OEM Sport Suspension ($150...5000 miles)
KO3 15,000 Miles (best offer)
OEM Bumper Cover (best offer)
Camshaft Position (CMP) sensor, checking
Required special tools and test equipment
VAG 1598/22 test box
Multimeter US 1119 (Fluke 83 or equivalent)
VW 1594 connector test kit
Wiring diagrams
Checking
- Disconnect 3-pin connector from Camshaft Position -G40- sensor.
- Connect multimeter US 1119 (Fluke 83 or equivalent) to measure voltage across CMP connector terminals 1 (B+) and 3 (Ground), using adapter cables from VW 1594 connector test kit.
- Switch ignition on.
- Measure voltage between terminals 1 and 3.
- Specified value: 4.5 volts minimum
- Switch ignition off.
If voltage is OK:
- Connect VAG 1598/22 test box to Motronic ECM harness connector page 01-54
- Check wiring for open circuit between ECM/test box and 3-pin harness connector, according to wiring diagram.
Connector terminal 1 to ECM/test box socket 11
Connector terminal 2 to ECM/test box socket 76
Connector terminal 3 to ECM/test box socket 67
Specified value: max. 1.5
- Check wiring for short circuit between ECM/test box and 3-pin harness connector, according to wiring diagram.
Connector terminal 2 to ECM/test box socket 11
Connector terminal 3 to ECM/test box socket 11
Connector terminal 3 to ECM/test box socket 76
Specified value: Infinity ohm
If wiring is OK (and voltage across terminals 1 and 3 is OK):
- Replace Camshaft Position (CMP) sensor.
If wiring is OK (but still no voltage across terminals 1 and 3 :
- Replace Motronic ECM -J220- page 01-55 .
- Carry out adaptation of throttle valve control module to ECM page 24-119 .
- Check readiness code page 01-57 . If Diagnostic Trouble Code (DTC) memory has been erased, or ECM was disconnected, generate new readiness code page 01-60 .
