Cannot connect with ECU
Old Feb 18, 2006 | 03:29 PM
rbeckwith's Avatar
New Member
Default Cannot connect with ECU
Just replaced the Powersteering rack in my 99 A4, 2.8 Quattro. Ran great for 2 days then all of the sudden the check engine light came on and the timing seems to be off, every now and again when I come to a sudden stop the engine cuts out, the car idles funny? Any way, took it to my dude, he hooked his computer to the OBDII and for some reason we are unable to link to the ECU to read the codes? Any suggestions?
Old Feb 18, 2006 | 03:35 PM
Im@wesome~ out!'s Avatar
you didn't plug it in hard enough ? I had that problem with my obd.. just had to push harder
Old Feb 19, 2006 | 07:06 AM
AudiMick's Avatar
Default Obviously the ECU has nothing to do with the Rack, but its possible you
disconnected or damaged a signal cable in the loom somewhere. Also check your battery connection.
Old Feb 20, 2006 | 09:16 AM
rbeckwith's Avatar
New Member
Default Re: Obviously the ECU has nothing to do with the Rack, but its possible you
I guess I could have damaged something when I took the dash apart to disconnect the steering link. Is there another OBDII port under the hood? If I disconnect the ECU can I plug right into it? I am not an electrical guy...I have no idea what I am doing, but I would like to learn more!
Old Feb 20, 2006 | 09:18 AM
rbeckwith's Avatar
New Member
Default Re: you didn't plug it in hard enough ? I had that problem with my obd.. just had to push harder
What did the computer say when you were not able to connect. I get power to the computer and the system says on the display "linking"...then it says "link error" and gives me no further reading. I also tried to use a "CarChip" to retreive data. I drove the car for 60 minutes and went to download the chip and there was no data stored on the chip...but it was getting power too...I am confused!
The Devil
Jan 23, 2008 09:17 PM
axman
Audi 100 / A6 (C4 Platform)
Jan 3, 2004 01:36 PM
bretto
Apr 3, 2003 11:34 AM
Hokie - STI avant
Nov 17, 2002 12:37 PM
SteveTT
Jan 21, 2001 06:40 PM
