Carputer project...
Old Jul 1, 2004 | 08:22 AM
DigglerD's Avatar
Default Carputer project...
So I got my carputer mounted....sound, wifi, everything is wired in.
Now the hardets part. I go my Lilliput 7" touchscreen today and am starting on the dash process. Anyone here have a template for the piece they may have used in the climate control relocation? It seems to be such a tight fit and I am having trouble making the piece with enough meat on the top and bottom to hold the climate controls stable in the cig lighter location.
Any warnings b4 I get started??
Old Jul 1, 2004 | 08:39 AM
simply J's Avatar
Senior Member
i made mine using 4 separate pieces and then epoxied them all to the climate control
Old Jul 1, 2004 | 10:32 AM
brrman's Avatar
Default Take some shaping foam and shave it down until you get a good fit.
By the way - it works much better if you take the electronics out of the plastic box so that all you have to mount is the faceplate
<IMG SRC="http://www.brrman.com/TEMP/DashInstall/Secured_Hvac_board.jpg">
<IMG SRC="http://www.brrman.com/TEMP/DashInstall/Glueing_Hvac_faceplate.jpg">
Here's a little info I wrote up on the HVAC relocation...
Moving the A/C Controls:
This had to be the most frustrating and difficult aspect of the interior modifications. First I removed the ashtray - it is not hard once the A/C control box is removed. The A/C unit is enclosed in a box, and would not fit in the ash tray area. Hmm. So let's remove it from the box. Now it consists of a faceplate with a ribbon cable to a circuit board containing the rear connections. Going to be tight, but I think it will go.
Next, build the faceplate that will replace the ashtray and holt the A/C controls. This was insanely difficult for me. I am no master at car modifications or stereo installations so what I did was cut out a square piece of cardboard and shaped it bit by bit as it slowly took on the form that would fit in the ash try position. Finally I got it fairly suitable and then used that as a template for cutting out the ABS plastic version. The plastic version was not perfect so I added bondo to the edges, sanded, etc to fix the defects in the shape.
Don't forget you have to cut out the rectangle in this plastic piece to accommodate the A/C controls. This is where I lost my cool several times. The cut out is so tight near the bottom corners that there is barely 1/8 an inch left to the faceplate. While putting the finishing touches on the faceplate (ie. sanding) I broke it. After cussing a massive string of expletives (I had worked all evening to get this far) I went to work on a second faceplate. I broke that one too. I nearly exploded. Sat down with a beer and told myself I would do another one tomorrow.
A week later I had the third faceplate done, but I had a slight crack where all the others had broken. I was getting no love from above. It did not matter anyhow. I primed and painted the faceplate and then epoxied the faceplate to the A/C front panel. Then added one last coat of paint over ther entire unit.FINALLY.
Wait - "How does the faceplate stay secure in the ashtray position?" you ask. I used a series of plastic tabs glued on the bottom of the face so that it would hook into holes I had drilled into the console. Then one more tab on the top (one that was not too tight so that I could remove the unit with a little force). The circuit board containing the plug wiring is simply laid in the back behind the face.
BrohrA4
Apr 22, 2005 01:13 PM
2.8beast
Apr 16, 2004 07:45 AM
chameleon
12v V6 Discussion
Aug 19, 2003 08:51 PM
jcs182
Audi 100 / A6 (C4 Platform)
Jan 18, 2003 04:43 PM
0 Pistons
Jan 20, 2001 02:17 PM
