Cat Efficiency below threshold?
Old Oct 26, 2008 | 07:49 PM
mktbully's Avatar
Default Cat Efficiency below threshold?
16806 P0422 Main Catalyst Efficiency - Below Threshold
reset the code a few times and it keeps coming back.
i did a search and some say it's just the O2. I replaced the front O2 about 20K ago. the rear one is still the orig one.
2000 1.8T-Q
about 130K.
the O2s are 100 bucks + so i rather not just swap parts just for S&Gs. what's the procedure to test the O2s on the vag-com?
do i need to replace the cat? the stock one is still on the car.
thanks!
Old Oct 26, 2008 | 09:24 PM
MrGoodbytes's Avatar
Default STFA
Apparently, it's "normal" for the ECU. Get it flashed by local Audi dealership.<ul><li><a href="https://forums.audiworld.com/a4/msgs/2632394.phtml">https://forums.audiworld.com/a4/msgs/2632394.phtml</a</li></ul>
Old Oct 27, 2008 | 04:52 AM
Nate (ETKA+Scumbag)'s Avatar
Keeper of the Cash
Tech Guru
Hit up the FAQ and look for generating a readiness code.
Old Oct 27, 2008 | 05:35 AM
mktbully's Avatar
Default ok i'm a little new at this...
<center><img src="http://i7.photobucket.com/albums/y293/FastA4Turbo/audi/18ATWReadinessCode.jpg"></center><p>so do i put in the group number and take the readings?
if the O2 is bad wouldn't it just tell me the O2 is bad?
thanks!
Old Oct 27, 2008 | 05:38 AM
mktbully's Avatar
Default oh geez...the car haven't see the dealers in a long time...
does this pertain to ATW motors also?
Old Oct 27, 2008 | 06:14 AM
Keeper of the Cash
Tech Guru
Default Well, this is how to test to make sure the sensor or cat is actually bad
You don't go to readings, you go to basic settings.
Follow the steps in order and match the parameters in the blocks.
Old Oct 27, 2008 | 06:49 AM
Joey T
Guest
Posts: n/a
Default Not an O2. It is a cat.
You have two choices.
1. Replace cat with factory. I has one I can sell.
2. Remove cat, sell to recycler, use money to buy test pipe, space out rear O2.
C. Gut cat, space out rear O2.
Old Oct 27, 2008 | 07:13 AM
Keeper of the Cash
Tech Guru
3/D: Install an HFC.
Old Oct 27, 2008 | 07:20 AM
mktbully's Avatar
Default ok i'll bite
Keep in mind i would like to find out what's broken before swapping in more parts.
where are you located?
how much are you asking?
how many miles on the current unit?
i might not get back to you for a week or so bc it's the gf's mother's car and she's on the road a lot.
Old Oct 27, 2008 | 08:21 AM
Joey T
Guest
Posts: n/a
Default Scotia, NY
Scrap value for a cat locally is $300. I would go $250, plus I pay your shipping your old cat back to me to scrap
80k or so. Pulled to install a TP on a KO4 car.
