CEL help
Old Sep 29, 2003 | 01:55 PM
ger19wmu's Avatar
New Member
Default CEL help
just had my timing belt/h20 pump/ tensioner/ cam seals.......all done and they went back and fixed a folded seal.....now i have a cel and it is always on, any ideas what to check.....not familiar with how they work on this car, but my old truck if the light came on, and it was just like a misfire or something the light would go off next time you started the car....or anyone in the westmichigan area have a VAG that can help me out??? TIA
Old Sep 29, 2003 | 01:59 PM
[tri]liament's Avatar
Default do you detect any symptoms that might've caused the CEL?
check the link for VAGs in your area. if you find someone that can help you out, bring a six-pack for their troubles.<ul><li><a href="http://www.steve-hall.com/cgi-bin/VAG-Locator.pl">http://www.steve-hall.com/cgi-bin/VAG-Locator.pl</a</li></ul>
Old Sep 29, 2003 | 02:29 PM
ger19wmu's Avatar
New Member
Default haven't noticed any problem, but not driving much since the light is on........
thats the thing, it drives fine, but every time i start the car the light is on......really starting to tick me off
Old Sep 29, 2003 | 02:31 PM
Default check your hoses, particularly the vacuum line
my CEL had been on for awhile with no noticable signs of trouble and no power loss. turns out my torn vac line was making me run lean, causing the CEL. an easy fix and now no CEL. but yeah, you'd have to VAG it to be sure. don't put it off, CELs should be taken care of asap.
Old Sep 29, 2003 | 02:52 PM
ger19wmu's Avatar
New Member
Default now it gets strange
i was planning on checking my hybrid bov for leaks and air filter for being clean tonight, just went to the car....and the cel is now off???? do they just stay on for a while, or is it possible i had a loose connection and now shouldn't need to worry as much?
Silvr_Surfr
Jan 20, 2008 12:55 PM
Durbin-1
Aug 8, 2004 02:59 PM
dpattanas
Texas Discussion
Aug 5, 2003 10:01 PM
\@Pazmanian Devil@/
May 28, 2003 03:23 PM
