Changing a flat
Old Sep 30, 2002 | 12:36 PM
J.Russ's Avatar
New Member
Default Changing a flat
Here's a handy Audi-owner tip: Carry a rubber mallet in your trunk tool area. You'll need it to loosen the freaking wheel from the hub after the bolts are out.
It's either the mallet, or bruise the hell out of your heel kicking the wheel loose.
Cheers,
J.Russ
98.5 2.8 pelikan blau avant qMS
Old Sep 30, 2002 | 12:37 PM
Silver Streakin''s Avatar
Member
or, rotate your wheels/tires on a regular basis :-)
Old Sep 30, 2002 | 12:38 PM
paul_858's Avatar
AudiWorld Expert
Default i've never had an issue with my wheel stuck on the hub... hell usually it comes right off before I
want it to.
Old Sep 30, 2002 | 12:41 PM
ex-quattro PETE's Avatar
AudiWorld Expert
or clean the hub and put some anti-seize on it before you put the wheel back on.
Liam in Montreal's Avatar
Elder Member
yup
Old Sep 30, 2002 | 01:01 PM
coocoomike's Avatar
after how many miles do you rotate? i plan on 5000, too mcuh too lil?
Old Sep 30, 2002 | 01:03 PM
paul_858's Avatar
AudiWorld Expert
5k is fine, usually do it with oil changes =)
Old Sep 30, 2002 | 01:16 PM
coocoomike's Avatar
yupyup, thats what im planning
 Michael S. Palmer
Member
Default same here, but my last one because I don't have much tread left on the RF because of a track day :-)
so, I swapped it to the RR for the Pocono North road course 2 weeks ago. And, guess who spun out (on the track) in the rain on a tight left-hander?
I need tires.
Old Sep 30, 2002 | 01:36 PM
JWG's Avatar
JWG
Member
Default Maybe on a rotor, but never on a wheel--rotate every 3500 miles or so . . .
and you will never have to use a mallet to get the wheels off the rotor.
Additionally, you can simply sand off the rust and/or corrosion on the surfaces between the wheel and the rotor. If you have never done so, you should do it every once in a while, as the rotor will often rust unless it's coated and, in any event, lots of super-fine brake dust particles will collect in that area.
shwndh
Feb 11, 2005 05:48 AM
Rack 'em Willie
Jul 24, 2003 04:32 PM
86_5K
9
Jun 1, 2003 10:29 AM
Blue2
10
Jun 23, 2002 04:56 AM
wwc3c
Sep 17, 2001 10:42 AM
